Warm starting problem325i msport, any common faults please?
Turkeylegs
Post Thu Jun 21, 2012 1:17 pm
Can anyone help with a 325 I sport warm starting problem, runs fine and starts from cold perfect, but turns over for a long time before starting when warm , smells like its gassing up[/list]
Post Thu Jun 21, 2012 1:30 pm
Hard to start when warm immediately after you stop it, or after it's been left for half an hour or so?
What engine management? (Age of engine.)
Turkeylegs
Post Fri Jun 22, 2012 9:23 am
After half an hr or so , engine 1990 original, any help much appreciated
Post Fri Jun 22, 2012 9:48 am
When the engine is hot, stop the engine by pulling out the fuel pump fuse, #11. Turn off the ignition and replace the fuse, then try to start it half an hour later.
There will be a small delay before it starts, at best, because the fuel rail will initially have zero pressure, but, allowing for that, see if it starts better.
Turkeylegs
Post Fri Jun 22, 2012 1:39 pm
Thanks tried it twice no difference , should I change seals anyway, anything else common on them, would love to have it starting properly, help
Post Fri Jun 22, 2012 1:49 pm
Have you checked the blue temperature sensor? It should read about 3300 ohms cold, dropping to around 600 ohms hot.
http://www.e30zone.net/e30zonewiki/inde ... emp_Sensor
Turkeylegs
Post Fri Jun 22, 2012 7:27 pm
Have changed the blue temp switch ,thanks anything else I could try?
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jun 22, 2012 7:32 pm
Have you TESTED the blue temp sender, to make sure the wiring is working?
Turkeylegs
Post Fri Jun 22, 2012 9:21 pm
Yes we have, any ideas would help, all electrical components have been replaced, coil , leads , dizzy cap plugs, it's fuel but what should I do next?
Post Fri Jun 22, 2012 9:43 pm
Have you tried cleaning out the throttle position switch (TPS), and setting it correctly?
They often fill up with oil, and it prevents proper operation.
In fact, this should be included in the Zone Wiki. :idea:
Post Fri Jun 22, 2012 9:48 pm
Ideally, you need to connect up a fuel pressure gauge to see what's happening. If that will be difficult, and the injectors are many 1000's of miles old, you could invest £60 in getting them rebuilt.
Turkeylegs
Post Sat Jun 23, 2012 12:15 pm
Thanks Brian I will make it so!
Turkeylegs
Post Fri Jul 13, 2012 10:28 pm
Have completely replaced with new the old injectors, runs a lot better , like lightning, but still has the same starting problem. Could the metering unit screw need adjusting , how is this done, and will it help . Any thoughts guys
Post Fri Jul 13, 2012 10:36 pm
Brianmoooore wrote:Ideally, you need to connect up a fuel pressure gauge to see what's happening.
