Fuel gauge
Hoobs
Post Tue Jun 19, 2012 9:18 pm
I want to fit an aftermarket fuel gauge as it's a PITA playing Russian roulette with running out. :mad:
I was thinking of using one of these digital jobbies but will it work with the OE sender?
http://www.ebay.co.uk/itm/stage6-petrol ... _792wt_907
Help / suggestions appreciated. :D
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
Mikey_Boy
Post Fri Jun 29, 2012 9:42 am
That looks pretty neat! I use a Stack fuel gauge myself to match the other Stack gauges I have in my dash - it's programmable so that you can get the full and empty reading right.
I take it you have measured resistance across the 2 fuel gauge wires at full and empty to get the full sweep?
Have a look a this for help on wiring - page 12, wires B4 and B5 are to the fuel sender:
http://luuk.xs4all.nl/bmwboeken/bmw%203 ... agrams.pdf
Bottom line is that you need something programmable to hook into the standard sensor...
Good luck! :thumb:
Hoobs
Post Fri Jun 29, 2012 8:59 pm
Thank you. :)
2002
Demlotcrew
Post Wed Jul 04, 2012 3:29 pm
I did say use Stack a few times now. winkeye
