Hi guys,
Long time no post and all that..
I have developed some very slight issues with my S50B32 VANOS.
The engine is overall in absolutely excellent condition. I beleive the donor car had had a replacement engine at some p
oint not too long before I got my hands on it.
I had weeping of oil from the exhaust side solenoid cover, where the wiring passes through the casing so I thought it best to change the oil seals throughout. They were replaced with the Vitron seals DanThe sells.
When I re-assembled it all I realised I hadn't marked the position of the solenoids so fitted them back they way they cams out - as best I could.
I have now developed (after about 5k miles) a slight VANOS growl on the inlet side on over-run at about 1000 rpm.
I always run the engine on good quality fully syn and currently have Mobil 1 10w60 Motorsport formula in there.. All golden and fresh.
Help!
Incidentally I also have a slight ticking from the top end on cold startup which lasts only a minute or so.. Probably time to check the valve clearances but worth mentioning.
Kind regards,
Jai Stanley
Calling all VANOS experts.
jaistanley
HenryM3
The ticking is quite probably the injectors, listen to them first before you start on the valve clearances.
