Gear linkage
driftwood
Are all e30 manual gear linkages the same? [/i]
Grrrmachine
- E30 Zone Wiki / Team Member
No, they're specific to each gearbox and engine combination. So you can't even swap between, say a 2.0 and 2.5, even though they both have M20 engines.
Might be able to switch between M40 linkages, but the only real confirmation is to check part numbers via RealOEM.
Andyboy
- Alpina Colada
Indeed - it's the distance between the tunnel gearlever hole and the back of the gearbox. The shorter the gearbox, the longer the linkage. You should see the linkage for an E34 518i - it's about 2 feet long!Grrrmachine wrote:No, they're specific to each gearbox and engine combination. So you can't even swap between, say a 2.0 and 2.5, even though they both have M20 engines.
