Air Con Wiring
scappi3
Post Fri Jun 15, 2012 8:44 pm
Hi all,
I have started to install an OEM BMW Air Con system into my E30. I have the Heater Matrix in but have a couple of wiring questions.
1) The main A/C loom.
I know where all the connectors go (i.e Compressor / Reciever Drier / Temp Sensor) - but i dont have clue where the individual wires go on the other end of the loom (see below) - any ideas?
2) The Heater Matrix Loom
The loom that is attached to the Heater Matrix has the A/C switch (obviously) but also a large black connector with two wires going to it - i have no idea about this one - again any ideas (see below)
Any help will be greatfully recieved.
Scappi3
Post Fri Jun 15, 2012 8:46 pm
The bunch of wires go into the fuse box.
The black connector with the two wires plugs into the engine loom next to the DME above the knee roll trim above the pedals.
Post Fri Jun 15, 2012 8:48 pm
http://shark.armchair.mb.ca/~dave/BMW/e30/
Click the link for wiring diagrams for the fuse box wiring.
scappi3
Post Fri Jun 15, 2012 9:05 pm
Thanks for the quick reply!
I find wiring an absolute nightmare!
I'm happy with the black connector, but do all the wires in the picture go into the Fuse box (the white connector looks like it plugs into something)?
If anyone has a picture of the fuse box with the A/C wiring attached - that would be a huge help.
Scappi3
jonny323i
Post Fri Jun 15, 2012 9:26 pm
These were taken when I removed one
Touring for life
scappi3
Post Fri Jun 15, 2012 9:34 pm
Your an absolute Star - that will make it ten times easier!!
Many thanks.
Post Fri Jun 15, 2012 9:56 pm
The white connector is in the fuse box.
Post Sat Jun 16, 2012 9:02 am
In Jonnys pics, the wires that are relevant to you are -
Thick Black/Green which is fuse 3
Thick Black/Blue which is fuse 18
The two small black wires in the space on Relay K1
The small Brown wire (earth) in the space on Relay K6
The small Brown/Black wire in the space on Relay K6
Demlotcrew
Post Sat Jun 16, 2012 11:07 am
You will also need to connect the open end of the diode to the the clear spade connector (brown looking plug). This stops the AC switching on when the fan hits slow speed with engine temps triggering the low fan speed with AC off.
You can also buy this loom new from BMW and don't forget to earth the loom at the nearside headlamp earthing post and you will need to release the 'locks' for the fuse connectors at the side before you try and push the female connectors in to the fuse box.
Andrew
