Will a 316 radiator be ok in a 325?
george101
Fitted my 325 into my e30 but I'm using a 316 radiator? Will this be ok? It's about the same length just abit wider, and has the filler bottle attached to the side.
if you've managed to plumb the hoses up then i don't see why it wont be ok .i'd keep an eye on the temp gauge after it's bled up without driving it .
not recommended though .
+ a yard full of scrap turds
george101
Yeah plumbed all the hoses up, Just gotta bleed the system and I'll keep an eye on the temp gaugemagpie wrote:if you've managed to plumb the hoses up then i don't see why it wont be ok .i'd keep an eye on the temp gauge after it's bled up without driving it .
Grrrmachine
- E30 Zone Wiki / Team Member
Be very thorough with your bleeding. The M20B25 is a bitch to bleed, and is also the most sensitive engine to overheating; the heads can crack very quickly, so do the job properly.
bmw9818
id of thought it would make a difference, ive got a 316i with a 325 radiator stays just above 1/4, only time its gone up a bit was when it was 28degrees and in traffic, id say it probably would overheat on hot days, but you should be orite seems like weve allready had summer!
