Hi ive recently picked up a rather neglected 1987 325 sport coupe.
One of the many issues that's bothering me, there is/was a fluid bottle under the rear drivers side wheel arch. Its now broken and rubbing on the wheel and now has no fluid in it what so ever.
Im sure one of you could tell me what its for i cant work it out?
Fluid resivour rear drivers side? 87' 325I sport
JJ26
Its not a fluid canister as such, its just part of the fuel tank breather system, a collection point for the pipes from the tank.
http://www.realoem.com/bmw/partgrp.do?m ... g=16&fg=10
G/90 316i M40 tickety tic!
ST185 GT4
Archless! Tech 1 project
E46 330d Sport
ST185 GT4
E46 330d Sport
Petrol can collect in this tank when filling the tank, when it is very full, or when the car is left on a tilt in the sun. It drains from the bottom back into the main tank, and has a vent pipe to the open air, or to the inlet manifold (on late cars), through a valve on its top.
You should be able to pick up a second hand replacement for next to nothing.
Ooko
Thanks guys. I best fix that then.
