bmw 316 1987 starting problem
flatfoot
Post Fri Jun 08, 2012 2:32 pm
Hi all,
First time posting.
Bought a 1987 E30 316 that has, at some time in its existence, had a push button start fitted.
It all seems to work fine, but there seems to be a regular blip.
Sometimes, when turning the key in the ignition, no dashboard lights come on and there seems to be no power connect at all. As a result the push button is useless.
I've tried turning off the electric to no avail. But after a few goes, the power suddenly comes on - and I can't work out why. I thought it was the heater once, then the radio, the headlights, the internal lights - once I was convinced that it was the rear-view mirror electrics, but none are consistently the problem.
Is it a connection problem, or even the battery?
Any help appreciated.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jun 08, 2012 3:28 pm
sounds most likely to be the ignition key itself. If someone's been butchering the wiring for a push-button, heaven knows what they've cut, and where, to make it all work.
Have a read about testing the Ignition Switch:
http://www.e30zone.net/e30zonewiki/inde ... ion_Switch
You can also test each of the wires here:
http://www.e30zone.net/e30zonewiki/inde ... rical#Loom
