Whilst fitting an illuminated gearknob, all these lights have failed.
All I know is :
- The gearknob wires had split plastic, ie. one or both have in all likelihood come into contact with the gearshift shaft
- No fuses have blown
All ideas / suggestions gratefully received.
Instrument Backlight / Ashtray / Gearknob - Gone!
Chris-W
eko
- Old timer
blown the bulbs maybe?
they are only tiny
they are only tiny
smithy318i
Congratulations. You have fried the dimmer on your headlight switch.
You can pull it to bits and attempt to repair this bit...
or you can buy a new switch.
Sorry for the sarcasm!
Check out this link
http://www.e30zone.co.uk/modules.php?na ... highlight=
Check out this link
Chris-W
The sarcasm is refreshingly welcome!
Thanks for the reply. I'll look at the switch. I'm amazed that the switch would go before a the fuse!
Chris-W
Fixed. It was the light switch.
Thanks again.
Thanks again.
DazzyA
Just checked the link, I have the exact same problem, cheers smithy 318i.
Pass me the spanner
