engine change wire problems
george101
Post Tue Jun 05, 2012 11:01 pm
right so ive put a 325i chromey engine in my 316 facelift, before i took the engine out the chromy i got spark and fuel. now the engine is in the facelift i dont i can manual wire the fuel pump, but i think the spark is to do with the relay that connects to the coil. ive plugged the ecu and engine loom in from the chromey to the facelift but ive come across the problem that this plug doesnt have anywhere to plug into??
if you click on the link you will be able to see the 3 pin socket thats next to the ecu, and has no where to plug into, where as before it did in the chromey. i traced the wires back and it does to go the relay that use to have a ticking sound when igniton was turned on.
if someone could plaese help or have a few pictures or tell me if i have to connect it to or wire to something else id be very greatful as im stuck now and have no idea.
thanks,
george[/img]
george101
Post Tue Jun 05, 2012 11:03 pm
sorry you will have to copy and paste the whole link to see pciture thanks
