Identifying a trick cam(M20)
eko
Old timer
Post Tue Jun 05, 2012 12:42 am
Ive bought a 325i that the owner reckons has had a £1000 Shnitzer cam conversion.
Now im thinking the owner is talking shit so before I pull the rocker cover off what identifying marks will I be looking for?
zaust
Zone day release
Post Tue Jun 05, 2012 8:31 am
Just measure the lobes on the cam and repot back. Not all cams will have markings apart from part numbers.
M30 Tech 1 Touring on gas.
Post Tue Jun 05, 2012 9:38 am
welli can tell you there are no identifying marks on alpina cams. A red paint stripe is about it. Schrick have shrick cast into them. Cat cams don't have anything marked into them either iirc
If it true then its probably a 270 ish degree cam made to ACS spec by schrick. You might have to take the cam out the head to glean any new numbers
