Battery drain
cee
Post Fri Jun 01, 2012 11:58 am
When left for around a week unused my battery will go flat. Are there any common causes for this? I have a feeling that the OBC stays on, should this be the case?
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
Captain_Birdseye
Post Fri Jun 01, 2012 3:58 pm
So, before parking it up for the week have you taken it on a few short journeys/long journey/ordinary kind of mix of the 2? I'm no expert but it could be a short or if you had a dodgy battery - maybe the obc. You've probably checked for boot light etc?
cee
Post Fri Jun 01, 2012 4:02 pm
Checked all interior lights - none seem to be an issue. Is a mixture of long an short journeys.
Captain_Birdseye
Post Fri Jun 01, 2012 6:08 pm
With the chill in the evening over the week being just enough to make the battery weaker, I would guess a dodgy regulator. If you've got brakedown cover, the next time it happens call 'em out. The mechanic will put the meter on the battery to see if it is charging at the rate it should, if it's even just abit unedr it's likely its the alternator (regulator). Someone who knows about electrics will hopefully be along here to answer your question. Probably cost about £45 to diagnose at an electrical garage.
johnl320
Post Fri Jun 01, 2012 6:23 pm
Could be diode breaking down in the alternator as mentioned, a clue to this can be a slight pulsing of the headlights/interior lights etc. Also check that your alternator is earthed to the engine block correctly
cee
Post Fri Jun 01, 2012 6:34 pm
Not got breakdown cover, but will check the other points. Thanks
