The thermostat is definitely 88 degree and working, turns out the one i replaced is working too
I changed the brown sensor about a year ago when i changed the blue one, so doubt thats faulty, and if it was would it work at all?
How would i clean a dirty harness plug? I managed to clean the prong on the sensor with abit of 180, made no difference
Just got the cluster out, the nut on the back is tight
e30wiki says:
"first unplug the cable from the brown plug, and join the two terminals with a piece of wire"
What two terminals?
also
"test by earthing pin 4?" How would i do this, theres nothing in pin 4
