Brake knock help
rotta
Post Tue May 29, 2012 12:47 pm
Knocking from under the car everytime i apply the brake... Any ideas??
Many thanks
Rotta :(
Rtaylor2208
Post Tue May 29, 2012 12:50 pm
Realistically it could be anything, have you had the wheels off to check the discs, pads, balljoints, bushes etc etc
rotta
Post Tue May 29, 2012 12:58 pm
started this morning on way to work can only notice it wen braking at slow speeds
aimlessrock
Post Tue May 29, 2012 1:15 pm
need more details mate, but as advsied have the wheels off and get the pry bar out to everything a good check.
E30 320i Convertible (1989)
190 Mercedes (1988)
rotta
Post Tue May 29, 2012 1:54 pm
Took it for a brief spin at lunch knock definately feels like its from under the pedal box or off side suspension somewhere must be a dead bush/joint id guess? also did notice that all the pumping of the brake pedal to have a good listen seemed to make the brake cylinder under the glovebox seem noisier than usual but i might be imagining that becuase i was listening harder??
rotta
Post Thu May 31, 2012 4:12 pm
Bottom ball joint is hangin out.
Rtaylor2208
Post Thu May 31, 2012 4:16 pm
Was the bolt holding it on missing altogether?
rotta
Post Fri Jun 01, 2012 10:53 am
no it was there just so much play in it :s
