Poly bush rear subframe? or BMW rubber
Jones
Post Mon May 28, 2012 10:31 pm
I have just paid for a rear disc subframe, before I fit it I will totally refurbish it, whats people opinions on the rear bushes with regards to going poly against BMW rubber items? I have poly wishbone bushes and they seem fine don't transmit any more noise.
My Mums E46 has the black poly trailing arms bushes which do seem to knock a bit when hitting a bump, I was going to go for the purple powerflex ones.
Thanks Jonesy
1994 E34 525i sport - Sold
1991 E30 316i LUX 2 dr - soon to be 318is
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue May 29, 2012 5:27 am
Mixed opinion on here. Some say they're great, others say too stuff, others say what's wrong with OEM rubber, the way BMW intended? The car won't last another 20 years, so you don't need bushes that will.
In my own experience of reading on here, I've only read complaints about harsh rides and failed bushes when talking about poly. I don't remember any threads about that from people who fitted OEM rubber.
Post Tue May 29, 2012 7:01 am
Lemforder bushes and danthe void-fillers. Job jobbed.
Barx325i
Post Tue May 29, 2012 7:31 am
it just depends what you're after really, oem bushes are designed to act with the rest of the rear suspension. Powerflex are possibly too stiff for normal road use, I had them on the iS, and as much as it's tight around the corners, it does lack the characteristic BMW feel.
There's nothing wrong with them, but the two compounds are very different & bmw didn't do things that way because they just happened to have that rubber lying around..
kind of an 'if it ain't broke' scenario
Post Tue May 29, 2012 9:16 am
Barx325i wrote: bmw didn't do things that way because they just happened to have that rubber lying around..
Jones
Post Wed May 30, 2012 1:26 pm
Thanks for the replies;) I think i'll go with rubber beam bushes as its cheaper as well, but I have seen some poly trailing arm bushes lurking around in the garage. Already got a poly diff bush fitted. ;)
aimlessrock
Post Wed May 30, 2012 1:35 pm
this thread is useful am im planning to overhaul the bushes....think i will stick with oem too.
E30 320i Convertible (1989)
190 Mercedes (1988)
