Floor sound deadening
leeparkes
Post Sun May 27, 2012 1:07 pm
Ive got the carpet out of my chariot and the floor is in good order although i have chiped most of the sound deadening off to see what its like underneath.
What is decent stuff to replace it with? self adhesive pads like this??
http://www.ebay.co.uk/itm/CAR-VAN-VEHIC ... 416627f79a
Its mad how loud the car is without carpets and deadening. 8O its like driving a tractor.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun May 27, 2012 1:25 pm
That's the stuff I'm using in my resto, but I've no idea how good it is. I haven't turned the engine on since September!
Post Sun May 27, 2012 2:37 pm
Sure I used that stuff lee-seems to have done a decent job-its easier to apply if you do it on a warm day or warm it up a bit first.
polsta
Post Sun May 27, 2012 3:00 pm
ive got that stuff, seems decent, although not put it in yet, maybe get a professional to do it , use a roller, heat gun,on a hot day - leave the pads face up layed out in the sun for a bit would be a good idea
the floor deadening is worth getting up on any old e30- found not heavy, but light bits of surface rust under mine,and got it all sorted before it could develop
polsta
Post Sun May 27, 2012 3:01 pm
out of interest- is it best to just stick to the oem areas or put more down ?
Post Sun May 27, 2012 5:21 pm
I put extra on the transmission tunnel, bulkhead and rear inner arch sections. Can't hurt.
leeparkes
Post Sun May 27, 2012 8:15 pm
polsta wrote: the floor deadening is worth getting up on any old e30- found not heavy, but light bits of surface rust under mine,and got it all sorted before it could develop
This is whats happened with mine so ripped all of it off to check/treat.
Cheers lads. 8)
G-Bear
Post Sun May 27, 2012 10:33 pm
If you read through this page there's a some bits about soundproofing, he's used Dynamat, but either way may be a few useful tips for you in there. :D
http://www.e30zone.net/modules.php?name ... &start=125
leeparkes
Post Mon May 28, 2012 12:24 am
I knew id seen it in a thread somewhere, this the route im going down
Thanks. 8)
Been researching tonight and its mad what folks have used to sound deaden, from carpet underlay to roofers tape. :mad:
Dynamat does seem top stuff though.
G-Bear
Post Mon May 28, 2012 7:42 am
Carpet underlay..? What a winner, especially when there's a bit of moister to soak up.
The carpets are out on mine at the moment for inspection, along with a bit of welding in the usual places I'm thinking that I'll be putting the same stuff down and to the same extent as to which in the thread I linked above.
Good luck with it chap, get some pics up if you can.. :D
leeparkes
Post Sat Jun 30, 2012 6:45 pm
Ive put some here chap. :)
http://www.e30zone.net/modules.php?name ... 80#2441580
G-Bear
Post Tue Jul 03, 2012 8:37 pm
Cheers for the link Lee, I just had a quick graze over the pics, but shall have a proper read in a bit.. Looking good from the glance.. Good man..
