Cab hood motor repair plate - anyone done it?
PeteE30Tourer
Post Fri May 25, 2012 11:22 pm
Evening all. Just wondered if anyone has tried fitting on the repair plates available on ebay for around £85 to fix the problem of a sheared off cam/lever inside the stowage area. Here's the thing:
http://www.ebay.co.uk/itm/BMW-E30-Conve ... 916wt_1140
Or this one (same thing it seems)
http://www.ebay.co.uk/itm/BMW-E30-Cabri ... 831wt_1397
I really want to get my hood working and after my success with getting the horseshoe to lift/lower electrically (as detailed in my post here: http://www.e30zone.net/modules.php?name ... 39#2421439), and reading loads of articles/threads on here, I reckon I understand enough now about how the whole thing works to get this sorted. I've already lubricated every single moving joint in the entire mechanism and exercised it manually several times to get it moving freely, so all that's required now is one of these repair kits to fix the motor drive.
So, anyone done this successfully? Any tips/guidance?
Back behind an M20, but now I can hear it better.
stew72
Post Sat May 26, 2012 7:46 am
buy this one
http://www.ebay.co.uk/itm/BMW-E30-Cabri ... 3f16fec248
but don't do what I did and buy it without checking that the electrical side of your system works.
Fitting is pretty straight forward if everything is still in place and not been touched, if motors have been removed its not too bad, but if the linkages have been dismantled then it may get more tricky to get the adjustmant right.
PeteE30Tourer
Post Sat May 26, 2012 10:06 pm
Thanks for the tips guys - they're both much cheaper than the uk eBay ones.
Gert_8
Post Mon May 28, 2012 2:43 pm
My cab has had this done in the past at some stage. Seems to have worked until I managed to brake the thing - plates still fine though!
PeteE30Tourer
Post Mon May 28, 2012 3:48 pm
Gert_8 wrote:My cab has had this done in the past at some stage. Seems to have worked until I managed to brake the thing - plates still fine though!
So what went wrong to break it then and which part failed? I'm concerned whether the rest of my system is up to scratch.
Gert_8
Post Mon May 28, 2012 5:58 pm
PeteE30Tourer
Post Mon May 28, 2012 9:12 pm
I have! Thanks for the recommendation.
BMWE30325
Post Mon May 28, 2012 9:38 pm
willnz wrote:I used this kit. http://www.ib-ideenbau.de/E-30-Seite-2.40446.html
Good quality, quite easy to install.
how much is it cant find the price anywhere?
Das_BMW_E30
Post Mon May 28, 2012 10:00 pm
I did some research, the age of the motors is now an issue, turns out the motor casings are made of some alloy compound that does not weld, and actuating the button to go in the opposite direction, mid lift, puts additional stress on the motor casing, this coupled with the age, shears off the top of the housing.
I bought this plate..
http://www.ebay.co.uk/itm/190684305470? ... 1558.l2649
Simply because of the full money back guarantee (including postage) if I was not happy, it took an half an hour to fit, and cured the problem.
Seller knew his stuff, was more than happy to answer questions.
Roofplates work, old alloy casings suck.
