Another indicator question
RedBook
Post Fri May 25, 2012 2:24 pm
Afternoon
So, I've read most of the threads on here about indicator problems and i've got some idea of what's going on, but could still do with a little guidance from you lot.
'90 318i. Driver side indicators were intermittently flashing double speed. Put it down to a loose wire somewhere and in the end the problem stopped so I forgot about it.
Today, turning on the driver side indicators results in a loud EEERRRRRRRR coming from behind the steering wheel and the hazards do not work.
Fuse 4 is fine and has never blown in the three years I've had the car. I've also not been messing about in the glove compartment.
I'm thinking the indicator stalk needs replacing? Other ideas?
Ta
RedBook
Post Mon Aug 06, 2012 6:25 pm
Shameless bump.
