Can I have prices and availability for the following please:
26117526611 - 1off - Prop shaft centre sleeve
26111225624 - 1off - Prop shaft rubber giubo
26121226723 - 1off - Prop shaft centre mount (complete)
23711133487 - 1off - Gearbox rubber mounts (pair)
33329061945 - 2off - Trailing arm bushes (pair)
33321136406 - 4off - Trailing arm hex bolt
07129900047 - 4off - M12 Nylock nut
33311129144 - 1off - Rear beam bushes (pair)
33311129676 - 4off - Side plate hex bolt
33331126136 - 2off - Rear beam collar nut M14
Thanks,
Rubber prices please
MrWhite
rust never sleeps
Cotswoldbmw
Hi There
26117526611 - 1off - Prop shaft centre sleeve £7.39
26111225624 - 1off - Prop shaft rubber giubo £65.71
26121226723 - 1off - Prop shaft centre mount (complete) £108.77
23711133487 - 1off - Gearbox rubber mounts (pair) £25.64 for 2 not sure if you want 1 or a pair
33329061945 - 2off - Trailing arm bushes (pair) £38.54 the pair
33321136406 - 4off - Trailing arm hex bolt £30.98 for 4
07129900047 - 4off - M12 Nylock nut £3.07 for 4
33311129144 - 1off - Rear beam bushes (pair) £65.45 for 2 not sure if you want 1 or a pair
33311129676 - 4off - Side plate hex bolt £4.72 for 4
33331126136 - 2off - Rear beam collar nut M14 £3.53 for 2
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 49370
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
