rear wheel bearing
jimmypee
Sat May 19, 2012 10:17 pm
What special tools are needed to remove replace rear wheel bearings. I know how to do the job but is there a puller required or is it best to take the hubs off to a garage with a press
Sanchez
Sat May 19, 2012 10:20 pm
Press i think is best.
fixedwheelnut
Sat May 19, 2012 10:21 pm
A puller kit like this is the sort of thing you need
Wheelbearing puller tool kit on Amazon
bigbird76
Sat May 19, 2012 10:44 pm
Sanchez wrote:Press i think is best.
If you can get the rear arm off i would 2nd this way as the press will apply equal pressure and safely remove the bearing.
You can press in the new bearing or use a length of m12 or m16 stud bar and some decent sized washers. Plenty of guides online on how to do it.
Leigh
Grrrmachine
E30 Zone Wiki / Team Member
Sun May 20, 2012 7:33 am
bigbird76 wrote:Plenty of guides online on how to do it.
Leigh
http://www.e30zone.net/e30zonewiki/inde ... eplacement
mcbonio
Sun May 20, 2012 11:45 am
I took mine to an indy garage who did them both for £180... there are some jobs I can do and some I can't be bothered doing.. wheel bearings are one of those.!
Also after weighing up the cost of buying the tools I needed and the time it would take, I decided to take it to an indy.
jimmypee
Sun May 20, 2012 6:28 pm
Is there a specific tool ie where to get it from in uk etc that someone has successfully used
alan1272
Sun May 20, 2012 8:43 pm
take the rear arms to a garage with a press and then either ask them to do it or ask if you could borrow the use of their press for an hour. replace the backplates while your at it.
cecotto479
Caution Unreliable Seller
Sun May 20, 2012 8:58 pm
I've had success with a cone bearing puller in a big slide hammer.
1981 E23 735i
