check light on dash
skooshy
Post Mon May 14, 2012 8:57 pm
hi there guys my check light on the dash clocks has stopped working i changed the bulb still no differnt....
only thing i can think of is that ive changed the surround as the 2 mounting brackets are broken and it came out a 320 without any obc.....
can that be it????
Post Tue May 15, 2012 12:07 am
skooshy wrote:hi there guys my check light on the dash clocks has stopped working i changed the bulb still no differnt....
can that be it????
You've changed what surround? If you mean the front half of the cluster, it's very possible that the bulb's working, but you can't see it. The little piece of plastic with 'check' on it, that the bulb shines through is totally opaque on cars without the 'check' module.
It's held in place by the same bracket that holds the SI board in place, and is easily changed.
