318 IS issues, any ideas?
mrjonchandler
Post Thu May 10, 2012 10:24 pm
Hi All,
Haven't posted for a while. I have my IS back on the road, MOT'd etc.
A few problems, have fitted new battery (background really).
Really struggling to get it up to normal running temp. Could this be a thermostat problem? The engine must be getting warm, it's the same as any other engine, so any advice helpful. Gauge seems ok, can occasionally move up towards the centre of the dial if stood after a run.
Next is a problem at tickover, it's revving and then falling, revving then falling, occasionally stalling. Could it be the MAF?
No experience of this so any tips advice needed. ECU?
Jon
Andyboy
Alpina Colada
Post Thu May 10, 2012 10:32 pm
Thermostat and idle control valve
mrjonchandler
Post Thu May 10, 2012 10:35 pm
Andyboy wrote:Thermostat and idle control valve
Thanks for this, is it a case of replace or repair the ICV, i guess replace the thermostat. Can you recommend one or are they much of a muchness?
Thanks anyway,
Jon
johnl320
Post Thu May 10, 2012 10:39 pm
Idle control valve can be removed and cleaned out with a carb cleaner aerosol from halfords etc. While you are in that area check for any split hoses. If your gauge sits around 1/4 and rises to 1/2 in traffic (but no higher) I would be happy with that.
HTH
john
