Diff removal
Ziggy
Post Sun Nov 13, 2005 7:13 pm
Hokay, how do I go about pulling a diff off? The donor car in question's got to be towed up the road to the scrappy afterwards, so I guess I've got to get the driveshafts out too :?
Post Sun Nov 13, 2005 7:27 pm
Unscrew the input flange nuts first, so that you can stop the prop turning with the handbrake.
Then take all the drive shaft bolts out, using the handbrake again to keep things still.
Unplug the speedo.
All that remains then is the big bolt through the bush and the four bolts that hold it to the subframe.
It's quite a heavy lump to lower out on your own.
I usually tie the inner ends of the driveshafts up loosely with wire when I have to move a diff less one around.
Ziggy
Post Sun Nov 13, 2005 7:34 pm
Cheers Brian :thumb:
Is the "big" bolt abnormally big? Ie do I need to make sure I've got a particularly big socket with me?!
Post Sun Nov 13, 2005 8:41 pm
4 big bolts are 22mm IIRC, or 19mm if I don't.
Jon_Bmw
Dangerous when thinking
Post Mon Nov 14, 2005 5:48 pm
As always brian is spot on with the advice, something to do is get a trolley jack underneath the diff, that takes the strain. Helped me a lot.
Davenotouring
Post Tue Nov 15, 2005 12:12 am
Think they're 19mm bolts Jon. Top advice as always Brian....
BMW 328i Cab - Daily Slag
Post Tue Nov 15, 2005 12:19 am
Last one I took off was on a 525e in a scrapyard, and we sat that one on it's roof. Definitely the best way to do it!
Richy325iTouring
Post Tue Nov 15, 2005 4:13 am
bolts are 19mm
allan bolts on the flanges are 8mm and the bolts on the prop are 17mm
i can get a diff off in about and hour or so on my own now
getting a bugger in takes a bit longer
koos
Post Tue Nov 15, 2005 8:54 am
Mine has torx bolts on the output flanges?
gcorky
Boost Junkie
Post Tue Nov 15, 2005 9:05 am
when you wind the 4 of 19mm bolts out a bit ,give them a good squirt to make it a little easier,some are tight!
Templ8e30
Post Tue Nov 15, 2005 9:57 am
koos wrote:Mine has torx bolts on the output flanges?
I've come across 2 e30's with torx bolts and both were a total bastard to remove, the torx heads corrode and become slightly undersize so the socket can slip and round it off.
I had to hacksaw one particularly stubborn bolt :x
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Ziggy
Post Tue Nov 15, 2005 10:07 am
Cheers for all the help guys... Didn't get it out in the end though :( Ran out of time & hey, it's a good excuse to get a LSD instead ;)
The hex bolts on the prop shaft came off on one side, but the other was a total b*****d for some reason. :hammer: So I left it. Would have persevered if it'd been a slipper though (& I'll know next time)! :lol:
:cheers:
