As above really,need to find the correct socket size,have done some reading up but have read 2 sizes....30mm 12 pin or 32 mm 12 pin?
Thanks,mike
98 328 rear hub nut size?
macas
blue30
Think it's 30mm, you usually get a new nut when you buy the new wheel bearing so you could just take that with you? Assuming that's what you're doing!
