Starting troubles
Mark-W
Post Sat May 05, 2012 1:05 pm
Been having problems starting the car, had to keep turning the key over an over till it started, problems got worse an now it wont start at all!
Battery is fine, changed the starter motor an its still the same, cleaned all the earths an connections, thinking its a relay now, which relay controls the starter motor?
What else could it be?
The cars a 90 316i
Thank you :)
BenHar
Post Sat May 05, 2012 1:31 pm
Mark-W
Post Sun May 06, 2012 11:32 am
Thanks Ben, didnt know about that!
Dodgy ignition switch by the looks
170sport
serial askhole
Post Sun May 06, 2012 7:14 pm
I've had almost the same issue with mine mate, found to be possible the two white blocks mounted on top of the steering tube. Take a look in here under 'fuel pump relay??'
Mark-W
Post Tue May 08, 2012 4:26 pm
Cheers for that, does sound the same, mine turned out to be the ignition switch itself :)
Billwill
Post Thu May 10, 2012 8:36 am
Mark-W wrote:Cheers for that, does sound the same, mine turned out to be the ignition switch itself :)
I have added a large relay to my 318i M40 as I find the ignition switches do not last for too many years otherwise.
Now the Start position of the ignition switch energises the relay which in turn supplies power to the solenoid. :)
milescook
Post Thu May 10, 2012 10:21 pm
A good excuse to install a starter button! winkeye
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
