hot starting
tony2311
Post Sun Nov 13, 2005 2:27 am
i got a F reg 325, the car starts and run great when cold but if i park it and try to restart it sfter 5 minutes it will not start, the starter motors runs normal , if i got back to it when it cools down then it will start,
Chrille
Post Sun Nov 13, 2005 10:00 am
I think it would be a good idea to replace the blue temprature sensor on the thermostat housing.
logan
Post Tue Nov 29, 2005 2:04 pm
check your fuel pump. i had the same problem before. i changed a lot of parts. but the problem remains. until i changed the fuel pump. try to check your fuel pressure when the engine is warm before change your fuel pump. just to confirm.
good luck.
Templ8e30
Post Tue Nov 29, 2005 10:52 pm
Sounds like a dodgy DME relay to me (white relay under the black plastic cover on the passengers side shock tower).
The relay can become intermittent causing start/no start and cutting out problems.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
