Dead battery causes
Fri Apr 27, 2012 1:46 pm
Hi all, my battery died today due to me leaving the lights on, the battery was dead dead, would this cause the ecu to reset itsel as when i drive if feels a bit lumpy and when i come to ajunction it idles a bit crappy? Thanks
milescook
Fri Apr 27, 2012 8:22 pm
I have a battery cutoff on mine as its a track car plus I have a battery drain issue so it helps!
After the battery is reconnected the car won't run optimal for a short while SA the ecu re-learns optimal fuel mixtures etc,that's what I've been told on here too.
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
320
Fri Apr 27, 2012 9:54 pm
since the battery problem, as it happened in the daylight, tonight i got in the car and turned the lights on half of my clock lights have stopped working, they were fine last nite,
