hi there just checking as i havent yet recived the books for my car...
are the electric mirriors and fog lights on the same fuse..
if not
are there any common prob i can look for ..
thanks
e30 320..fog lights and electric mirrors on same fuse please
eko
- Old timer
Foglights use a fuse each,number 29 ad 30 and mirrors are number 19.
lisa325is
Ok that's great thank u..mabe have to give the switch ago as the fuses in the engine fuse box wer all spot on whn checked with test lamp!!
Thank you..
Thank you..
Grrrmachine
- E30 Zone Wiki / Team Member
If you're ever unsure about fuses, you can check the Wiki
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
There's links to each item in there, as well as the Wiring diagrams if you have a fault.
