Fuel hose diameter?
mcbonio
Thu Apr 19, 2012 11:19 pm
Need to change the fuel hose under the bonnet, from fuel filter to fuel rail. Looking quite brittle.!
Anyone know what diameter it is? 6mm?
Thu Apr 19, 2012 11:34 pm
ETK (realoem and similar) will confirm it as 8mm bore.
mwggriffiths
Thu Apr 19, 2012 11:58 pm
Definitely 8mm ID, I've just done mine.
On the IS there are hoses from the body onto some solid pipes mounted to the engine, then more hoses under the intake from those solid pipes on the fuel rail. Those short, hard to see pipes were REALLY tired - it's not a massive undertaking for some extra piece of mind :) (This is also 8mm)
1990 318iS, 1998 E36 328i Touring, 2001 740i Sport, 1971 Range Rover
Fri Apr 20, 2012 7:13 am
Make sure whatever pipe you buy has "suitable for unleaded" or similar stamped on it.
Grrrmachine
E30 Zone Wiki / Team Member
Fri Apr 20, 2012 7:29 am
Come on mc, almost every question you ask has it's answer in the Wiki...
http://www.e30zone.net/e30zonewiki/inde ... Fuel_Hoses
Also, someone's signature pic is making my anti-virus go off...
mcbonio
Fri Apr 20, 2012 10:07 am
I know every question is in the wiki.. but it wouldn't spark off such great display of knowledge between the e30 folk if people didn't ask.! :) (i'd also get moaned at by my boss if he saw me on the t'internet)
Yeah every time I opened the bonnet I got a faint whiff of fuel, the hose clip on the intake manifold was loose, also hose looks to be too short as its stretched tight from the filter to fuel rail. It also is pieced together with a join in it, for no reason whatsoever.
Don't like the look of it so time to change.!
Cheers guys.!
jmc330i
Fri Apr 20, 2012 10:36 am
Grrrmachine wrote:Come on mc, almost every question you ask has it's answer in the Wiki...
Whilst the Wiki is great (I use it now after the work that's gone in to improve it, by you I think??), actually asking a question can be better. The OP has had 2 pieces of advice that he wouldn't of got had he just read the Wiki.
And just extend on what mwggriffiths said, if you're replacing one 'tired' rubber fuel pipe, its worth doing them all.
Not on an E30, but I've had a rubber pipe split after I renewed one other that had started leaking. Obviously that pipe was past it, but I would say that as the pressure will always take the route of least resistance, once I'd renewed 1 hose the next weakest point was the damaged one I couldn't see. Result was 1 race not finished, 2 empty fire extinguishers and me needing to rebuild a stock car! :(
James
'91 325i Sport
'93 318i touring 16v
Grrrmachine
Fri Apr 20, 2012 10:39 am
Yeah, I do appreciate the new questions; they also show me what info the Wiki is still lacking :D
I'd just like to know people are looking at the Wiki for the basic stuff, that's all.
mcbonio
Fri Apr 20, 2012 11:09 am
Yeah to be honest I do look at the wiki, but its also nice to have a little chat with the peeps on there, there are a nice bunch.. :)
adam-325i
Fri Apr 20, 2012 1:44 pm
its 8mm bore pipe iv used diesal leak back pipe seems to work fine
Fri Apr 20, 2012 6:42 pm
mcbonio wrote: It also is pieced together with a join in it, for no reason whatsoever.
That appears to be standard OEM fit and is shown on realoem - my Touring was the same - I replaced it with a continuous run of hose rather than re-fitting the joint.
mcbonio
Sun Apr 22, 2012 1:57 am
Ok so refitted a new length of hose today, the old one was quite bad, split end to end and when I pulled on both ends the whole thing just opened up.
I also changed the dizzy cap and rotor arm, I must say out of all the maintenance I've done so far this has made the greatest difference. The contacts on the dizzy were black and thin and the metal strip on the rotor arm was just a tiny black strip, almost no metal left.!
The engine is so smooth and the pick up is amazing, the air filter actually makes an little induction whoosh now at WOT can you believe. Its never performed like this before...
Its also sorted out my low idle issue, no longer at burbling 500rpm but a perky 650rpm and it doesn't drop when I put it in gear or when the lights are on. A great day all round!
