another cabrio rear speakers question.
d1mkaz
Post Mon Apr 16, 2012 3:37 pm
I was reading the posts about rear speakers on cabrio only to get confused :mad: , so to clarify I started another one
what is the size are they 10cm or 13cm?
if they are 13cm would I be able to fit those so the speakers won't touch the speaker covers for example:
http://www.alpine.uk.com/p/Products/typ ... 5/spg-13cs
cabrio drivers please advice on this, thanks
hazd31
Post Mon Apr 16, 2012 4:20 pm
Yep 13cm, they will fit in the original space, no need for the covers, there hidden anyway!
d1mkaz
Post Mon Apr 16, 2012 6:39 pm
hazd31 wrote:Yep 13cm, they will fit in the original space, no need for the covers, there hidden anyway!
thanks!
PG325
Post Tue Apr 17, 2012 7:42 pm
Definitely 13cm in the back and front.
Why would you want to fit component speakers in the rear of a cab, these should go up front really, with coaxials in the rear.
Components in the rear will give a focal stage behind you and not in front, might sound a bit top ended.
Try talkaudio.co.uk for useful ICE info.
d1mkaz
Post Wed Apr 18, 2012 10:22 am
PG325 wrote:Definitely 13cm in the back and front.
thanks I'll check that, I don't want components on the back, that was just example, I want the speakers that would fit straight in without any issues with the original covers.
