Brianmoooore wrote:I wrote "the usual reason" NOT "the only reason", so don't make too many assumptions yet.
Once you've dug out the ECU and reported back as to what condition it's in, then I have a whole batch of tests lined up for you, depending on what you find.
Ill be in touch over the weekend. I'm going to strip car now its off road anyway. Might as well do a rust hunt. In for a penny in for a pound?
polsta wrote:to unblock sill drains, EVERY E30 owner should do half regularly, get a bit of wire coathanger or something, feel along inside/under of the sills and youl feel the slight raised bits, poke it in and give a move around and make sure they are clear, 4 on each side or something
buy a new ecu from here for £10 and get it sorted and maybe need some new solenoids if theyve burnt out if it has been flooded
Ill be honest... unblocking sills has never even accrued to me!!
Thanks for the advice Polsta and Brianmoooore. Ill be back looking help soon
