oil pressure light ?
BATTS91
Post Sat Apr 07, 2012 3:08 am
i turn my ignition on all red lights come on exccept oil pressure light would this suggest wireing is not attached somewhere or duff sensor ??? m50 by the way [/list]
Post Sat Apr 07, 2012 9:12 am
If you unplug the sensor and earth the single pin in the plug the light should come on, if it does it shows the sensor is not working, if it doesnt first thing to check is the bulb in your clocks
BATTS91
Post Sat Apr 07, 2012 11:17 am
thanks dan ill have a looky in abit :)
VW-will
Post Sat Apr 07, 2012 6:46 pm
Nice and quiet on the way home batts? Lool
BATTS91
Post Sat Apr 07, 2012 9:11 pm
quiet wills take the pish man me ears were ringing for ages , but it dont scrape on anything now ill get centre box asap ,
also had a lil look in dark as fell asleep am i correct in thinkin oil pressure is on inlet side sort of next to alternator if so i earther it to engine mount n fo0k diddly came on ,
VW-will
Post Sun Apr 08, 2012 11:30 am
Back of the oil filter housing dude :-)
BATTS91
Post Sun Apr 08, 2012 12:30 pm
yep well earthed it n fook all which says somthing else gna pull clocks out
Post Sun Apr 08, 2012 3:58 pm
Wire connected correctly at the engine loom plug? Try earthing pin 5 (black/brown) at the body socket, with the ignition on.
BATTS91
Post Sun Apr 08, 2012 4:29 pm
ok ill get on it in a mo see what happens thanks
BATTS91
Post Sun Apr 08, 2012 8:55 pm
thanks for advice guys its the sensor i tested from loom plug straight to battery for a perfect earth, then connector on the plug both times light came on boshty get one next week :)
