I was pleasantly contented when the radio tuned in
The one plug system with 16 pins I noticed are arranged differently to the others I have...could this be the reason and is there a solution ?
Grateful for any help.
Thanks,
Felipe
My head unit shows 4 dashes as soon as you connect power to it. You then need to use the 1,2,3,and 4 buttons to enter the code. Then the right arrow button to accept the code.phillip wrote:Cheers Martin..will give it go !
the other radios will not show 'code' rather four dashes...and won't except numbers...
