cheers guys
test procedure to what is/isn't working electric hood?
matt86
Hi is there a test procedure to see what is and isn't working in my electric hood, also does anyone have a pic of the hood button (i know this sounds stupid but want to make sure i am pressing right button), secondly are there test voltages i can measure, or a way to test motors and mechs?
cheers guys
cheers guys
kolee
Matt,
I'm going to help you get this sorted very quickly and very cheap.
There is a man i know, in his 70's. He has restored many classic cars and is an auto electrician.
He should have retired years ago, but does it for the love of fixing cars, so you know he wont rip you off.
He is based in Chalford, very close to you.
Give him a call and tell him Wayne from Painswick recommended him to you - make sure you let him know i recommended him!
His name is Terry Coventry of TC Services 07973 551 376.
If your fault is electrical, he will find it.
- E30 Zone Meets/Events Team
Sure your hood is electric and not hydralic?
Thought the later ones were/?
matt86
Hi rav, yes its elctric with 2 motors one to close the horseshoe and one to close the roof, also there is a hood control board tucked under the carpet, at least I think this is what it is, I guess there must be one or 2 relays too.
Kolee thank you for the advice I've heard people recommend him before and was told he was cheap, will try this, thank-you for your help mate.
kolee
Either way, give terry a call, he wont charge if he cant fix it and he can pass you on to someone who will fix it.Rav335uk wrote:Sure your hood is electric and not hydralic?![]()
Give him a call.
cecotto479
- Caution Unreliable Seller
The hydraulic ones are the earlier ones - only in Motorsports and M3s I think.
What happens when you press the button?
1981 E23 735i
matt86
nothng at all mate, cant hear or see anything move. cheers
matt86
adit
the button is the rocker switch with the diagram of the roof up and roof down, to the right of the hazard and rear screen blower switches, Matt
[quote="bss325i"]
matt86
ah I thought it was that, mine are pretty worn off though, yes it doesnt do anything when pressed, I don't know what to do what you suggested adi and convert to manual, just would be nice to have the electric side working as long as it doesn't cost a fortune.
Might do what Kolee suggested and get this auto electrician to have a quick look, as I've heard he only charges 30 a hour.
Thanks Adi
Matt
Thanks Adi
Matt
cecotto479
If absolutely nothing happens, you are unlatching the roof and "breaking" it before pushing the button?
First thing is do is check fuses and earths to make sure there is power at the roof system.
Then synchronise the motors following the procedure in the wiki.
Then there's a micro switch in the header rail that tells the control unit that the roof is unlatched. Without that signal, nothing happens when you push the switch.
There are Bowden cables that connect in the boot too. They prevent the system from operating if the boot is open.
If both of these are OK, I'd be on to the control unit.
1981 E23 735i
stew72
Matt, check the following first -
Is the pivot on top of the main motor drive broken or damaged?
To the best of your lnowledge have the levers on the main motor drive been separated from the roof mechanism?
