Slowly went up to red just as i got home, noticed that the fan was going slow and you could easily stop it. Could that be it or is it the head gasket ?
Thanks totaly pi$$ed off Andrew
First day out in the cabby and its overheating
atlantis
E30 325i cabby
E39 525i sport in Atlantis blue
If the fan was going slow and you could easily stop it despite the engine being very hot then it sounds like the viscous coupling for the fan has failed.
Did it overheat on the move or just when you pulled up?
atlantis
I could only go slow behind someone so it just crept up slowly
E30 325i cabby
Yes, sounds like the viscous.
atlantis
Big job??
E30 325i cabby
kam-325i
No.....atlantis wrote:Big job??
just arkward......
you can either replace the whole fan and viscous assembly or just the viscous coupling.
just remove the fan from the end of the water pump.
i think its a left hand thread though.
