Rear view mirror
greentouring
Sun Apr 01, 2012 2:52 pm
I managed to knock the rear view mirror off on my touring. It's not broken, but it's a tough spring loaded type fitting. I can't access the area to give enough force to knock it back. Any suggestions?
I'm hoping the head lining doesn't need to come off.
bmw9818
Sun Apr 01, 2012 4:19 pm
you might need to remove the panel, if you cant get it in as it is just remove the 8 screws on the visor brackets and just pull it down slightly if it gives better access, try greasing it up, i just used some sillicone spray but anything shold do,pop one side in then just push it in as hard as you can
greentouring
Sun Apr 01, 2012 6:03 pm
Thank you. I was wondering if removing the visor brackets might be enough. I'll give it a go :D
jonny323i
Sun Apr 01, 2012 6:21 pm
i had the electric roof in mine and removing the access panel was the biggest help to the motor
Touring for life
