Hi what is the best product to remove scratches, I have used tcut before and its ok, but not very good on metallic finishes. There's so many makes and types of rub compound, was wonderings if meguiars is good, or g3 compound. Is this too coarse to remove light scratches?
whats best product to remove scratches
matt86
Get a valeter/detailer to have a look at it and quote you on it.
You can get OK results yourself with the products you've mentioned but IMO a professional will get it as good as it can be - worth paying the extra for.
matt86
Cheers mate
Grrrmachine
- E30 Zone Wiki / Team Member
All depends on the scratches; have they gone through the clear, or the base, or right down to the primer.
For that reason, metallics are a lot harder to fix than solid colours, so if you don't know, consult a pro.
matt86
The cars a black mercedes van and they are faint white, so don't know if this is the primer? Shall I try a bit on a small area and see what happens? Cheers
matt86
Just tried some black colour magic plus(tcut equivalent) for metallic cars as found it in back of garage, only done it once and although you can just about see the scratches its miles better than it was, maybe a few more coats will get rid of them completely
P.s its hot in my van down torquay today, wish my convertible wasn't in gloucestershire and I wasn't working.
Rtaylor2208
The best way is to buy a mechanical polisher and for deeper scratches get some G3 and polish it out. It will also bring up faded paint.
You have to be careful not to burn the paint so while you are getting used to it you can keep the paint wet with a sprat bottle of water.
acidman
g3 isnt too course ive used it for years just keep it wet and be carefull or you will take the paint back and need to paint the full pannel this is only good to use if the scratch has not gone to the primer or metal and use autoglym deep gloss to bring back the bling if you are sure you can do it yourself without killing more paint work then use car plan rubbing compound in the green tube its a lot courser but works out deap scratces better all these methods can be done by hand no tools required exept elbow grease.
