I bought a full set of sport seats for my 318i roughly 7 months ago. as I'm coming closer to getting the bitch on the road i decided to put them in. But on the drivers seat the left hand side of the back seems to drop with the sound of a ratchet mechanism slipping and the passenger has the same issue but on the right hand side. anyone encountered this before and anyone got any ideas of how easy it is to repair?
cheers
Sports Seats.
yung-gun
adit
that sounds like the seat adjustment mechanisms are worn. they are fairly easy to replace and i'm sure comfort and sport seat mechs are the same
[quote="bss325i"]
I had this on mine recently - the seats obviously need to be out of the car - remove the plastic covers where the ratchet handles are, and you can see the mechanism.
Blast it with WD40 and operate the handles, move the seat back and forth to make sure the WD40 can do its job - will almost certainly do the trick - its the ratchet mechanism sticking which means it doesnt engage properly to lock the backrest in place.
You need to do both sides for it to work properly.
Also worth taking the cover off the backrest and making sure the large cross-head screws are done up tight if the backrest still feels a bit loose.
Had to do this job on more than one of my E30's - never had to replace a worn mech yet
yung-gun
Mariza
Agree WD 40 is the answer no need to replace any of the parts,
just spray and operate the mechanism several times. Mariza
325i Alpina 1988 Lachs Silver leather trim
88,000mls Apr 2012
88,000mls Apr 2012
