hi, i have a problem with the wiring connection to the electric fuel pump. i think the wire has a cut because when i wiggle the wire the car starts with no problem i'm thinking of chopping this wire and soldering a new one on, but the problem is the wire is not long enough, can anybody help with more knowledge any advice will be appreciated the car is 325i on 87 plate because now the fuel gage don't even work but the reserve light comes on so at least i know when to fuel up.
many thanks helmi!!!
fuel pump
Grrrmachine
- E30 Zone Wiki / Team Member
I'm not exactly sure what your question is, so have a read of this:
http://www.e30zone.net/e30zonewiki/index.php/Fuel
helmi25cab
My question, is it good idea to cut the wires as I have very little knowledge of eletrical will be creating a bigj ob for my self or should I not
Touch it and take it to someone who knows more than I do?
helmi25cab
Anyway had ago at it this morning and sorted now had to change the connector as the old one completly fucked dont know how it was even working thanks anywayz but the only thing that is still not working is the fuel the fuel gage i have check all of the fuses and relays i dont know what could be the problem help
Where is your fuel pump?
Tom_Maverick
If you live close to me I could have a look.. I haven't really had much to do with a leccy pump but I am an electronic engineer.. It's probably something simple..
helmi25cab
Thanks m8 check your inbox you will have my number!
helmi25cab
