Hi, Was wondering if someone could help me diagnose a recurring problem with my E30 325i Cab. Basically when you have the heater fan running the fuse burns out in no time?
Fuses burning out with the interior fan switched on - Cab
Grrrmachine
- E30 Zone Wiki / Team Member
does "in no time" mean a few minutes, or instantaneously?
If it's instant, you've got a short somewhere. If it works for a little bit (even seconds) and then breaks, then your fan blower probably needs some maintenance:
http://www.e30zone.net/e30zonewiki/index.php/Heating
markysparky
It normally works for around 5mins with the fan on position 3 or 4. It is operational until the fuse burns out. Tried a 30 amp fuse, lasted longer but still burnt out eventually. Thanks for your reply.
Grrrmachine
Heater blower should be a 30A fuse, in position 20. What fuse was in there before?
Get the motor out and lubricate it, based on these steps:
http://www.e30zone.net/e30zonewiki/inde ... nly_on_Max
As above. Fuse should be 30A.
Get the motor out and lubricated properly ASAP - it can't be done properly without removing it.
In the meantime, avoid having the fan switch on any position other than off or full, or you will destroy the fan speed resistor.
