a few different faults/problems
matt86
Post Fri Mar 23, 2012 9:45 pm
Hi firstly my car under braking does a fairly loud clunk most of the time, I was thinking cv joint, or could it be a loose engine mount, I know something like this is hard to pinpoint without seeing or driving the car, but any suggestions would be good, also its only just started happening, but had a 200 mile trip palnned for tomorrow, do you think it will be ok if I take it easy?
Secondly my steering when turned makes a high pitched noise, sounds like a dry bearing to me on the wheel itself, rather than a belt or something, sounds like sonething needs greasing anyway, again and advice would be welcomed.
Matt
johnl320
Post Sat Mar 24, 2012 6:52 am
Check the brake backplate isnt rubbing on thr disc, have you had thay wheel off recently for any work to be done?
318isPMK
Post Sat Mar 24, 2012 6:58 am
mine makes a similar noise and Ive had it off I greased the nut hoping it had something to do with that but made no difference
