gear linkage kit
Rorym2010
Post Thu Mar 22, 2012 12:44 am
hi does any one know where i can get a gear linkage kit for a 3dr 89 316i preferably online???? cheers
Post Thu Mar 22, 2012 6:49 am
For all the component parts you need to refresh the gear linkage its dealer only.
Post Thu Mar 22, 2012 8:48 am
capri_rob wrote:For all the component parts you need to refresh the gear linkage its dealer only.
And, if you go to our 'traders' section, you'll find our own on line BMW dealer, Cotswold BMW.
What, exactly, is the problem, or what are you trying to achieve?
Rorym2010
Post Thu Mar 22, 2012 9:27 am
theres loads of play in my gear stick that much so when i turn a corner it leans from side to side its been fitted with a short shift gear stick an i can lift it out up about 2" which also doesnt seem right to me havent investigated yet but ive got a feeling the ball cup bushing is completely shot cheers for your help
Post Thu Mar 22, 2012 9:40 am
This should help - same diagram your dealer uses: http://bmwfans.info/parts/catalog/E30/2 ... ing_parts/
Part #14 is usually the main culprit for sloppy linkage, but 2, 4, 6 and 11 can contribute as well.
14 was subject to a modification at one point, and if your replacement is different from the original, you will need the matching 11 anyway.
#14 sits on a shaft protruding from the rear of the gearbox, which passes through a small oil seal. It's a good idea to change this seal while 14 is off.
Rorym2010
Post Thu Mar 22, 2012 9:58 am
cheers mate just waiting on a reply now from cotswold dealer posted on there 2 days ago about a gear linkage kit but no reply do you think buying a secondhand gear shift arm off ebay would do the trick ?? as ive got to do a 3 and a half hour journey in it soon and when ive been driving for 45mins or more sometimes it gets stuck in gear mainly when im changing from 1st to second it wont come out of first without a good tug on it??
Post Thu Mar 22, 2012 1:27 pm
Rorym2010 wrote:cheers mate just waiting on a reply now from cotswold dealer posted on there 2 days ago about a gear linkage kit but no reply do you think buying a secondhand gear shift arm off ebay would do the trick ?? as ive got to do a 3 and a half hour journey in it soon and when ive been driving for 45mins or more sometimes it gets stuck in gear mainly when im changing from 1st to second it wont come out of first without a good tug on it??
I've asked for two quotes for parts from Cotswold in the last two weeks, and have had the reply within an hour in both cases. Email is the best way to contact them.
