I'm sure the steering isnt right now, feels heavier pulled over lastnight checked tyres PSI was perfect, they are evenly worn, no lumps bumps, tightened wheel nuts after some advice.
mechanic put it on a ramp couldnt see anything that would cause the symptoms I described.
Power steering fluid is fine at a loss... any idea's?
Also noticed at least twice the clutch has went spongy.... like no resistence. Does that make sense? just age... should I worry only when it doesnt work?
