eng pic with parts numbered is at this url:
http://24rsk.thor.prohosting.com/M20Engine/tempspic.htm
I was advised that this is the L-Tronic injection system.
1 - Brown white lead, measurements shows +12V voltage, removed whiled engine running at idle, no noticeable change
2 - Red White lead, same but -12V, still no noticable change.
3 - Single lead - in dash Temp gauge, when removed the temp gauge needle goes dead.
4 - Brown lead - not connected, seems to be the earth connection, no role whatsoever
5 - 2 Lead plug, removed while engine running, no noticeable change, measurements show no voltage running trough it. What role does this plug have? it's present on all the older L-tronic injection systems, the M30 engine seems to have it too in the same location.
Where might be the temp sensor that informs the ecu of the temp?
Where is the thermotime switch? are this one and the same sensor?[/url]
