Hello Lad's,
I have recently put a short shift in my car all is good how ever when car is in motion and you put it in second gear you can feel somthing touching, when you hold second gear and push it to the left you get a little knocking noise and a feeling like something going round. The car drives fine in all gears and change's well.
Has anyone come across this before or can anyone shed any light.
Thank's Gill
Gear linkage
biggill
tom325sport
Sounds like your selector rod needs bending slightly.
Have a look here....
http://www.e30zone.net/e30zonewiki/inde ... conversion
biggill
Cheers tom will give that a go.
Gill
Gill
http://bmwfans.info/parts/catalog/E30/2 ... _mounting/
If the problem is contact with part #3, this part can be removed with no ill effects. It was only required in conjunction with early versions of #2.
biggill
Cheer's tom, all sorted bent the rod a little and work's spot on.tom325sport wrote:Sounds like your selector rod needs bending slightly.
Gill
tom325sport
No worries. Glad it worked for you.
