injector electrical plug under inlet manifold
redror
Post Sun Mar 18, 2012 2:42 pm
Hi, im in the process of removing the injectors from my 89 325i for refurb and am stuck on removing the electrical plug the goes from the rail to under the inlet manifold, i have disconnected the plug but how do i get it off the metal bracket so as to get the electrics out of the way to get the rail out? cheers
sharpster73
Post Sun Mar 18, 2012 3:30 pm
Hi, there is a lock ring under the metal plate which must be turned to release the plug. It should be easy to unlock.
Good luck
Light travels faster than sound. That's why some people appear bright until you hear them speak.
redror
Post Sun Mar 18, 2012 3:32 pm
sorted, yeh finally saw the lock ring as i bent the bracket up a tad, cheers for the help
sharpster73
Post Sun Mar 18, 2012 5:20 pm
:cool: :)
