Temperature gauge problem 320i
ah
Ive changed the thermostat and the heating is spot on,but the temp gauge goes to the quarter mark and occasionally 3 quarter.Also when I stop and turn the engine off,when the engine is restarted the temp gauge will have dropped and takes a while to read OK again.I have checked the brass nuts and they are OK and tight.
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
SGP
You may have a thermostat that opens at a lower temperature than the previous one, iirc that would cause the gauge to display a lower reading. That happened to me in a ford transit some time ago. If you haven't already, check/clean the sender connection on the engine.
If it ain't broke..
Fix it till it is
Fix it till it is
Gauge definately should not go past halfway - IIRC the gauge is non-linear - i.e the "normal" range is between 1/3 to halfway on the gauge and only covers a few degrees of temperature - anything more is too hot.
If its definately not a gauge fault sounds to me like you have an airlock somewhere in the system.
You can try checking/changing the brown sensor on the engine as this sends the signal to the gauge too but my money would be on an airlock.
Bleeding M20's can be a pig - if you've got Andyboys restoration bible it gives a very comprehensive description of how to do it without getting airlock issues
