Removing Engine loom through,,,,,
gooner1
Out humping Reindeer
Post Tue Mar 06, 2012 6:56 pm
... the bulkhead, is it a matter of brute force :?:
This is order to change to the later 1.3 Motronic, so the ECU
has been removed , obviously. :)
Jim320i
E30 Zone News / COTM Team
Post Tue Mar 06, 2012 7:23 pm
From inside, push the side of the larger rubber grommet inwards into the hole, it should pop through slightly, the rest will follow and once the grommet is out the way it will slide out easily enough. Pulling on the loom might cause damage.
