JOM coilovers. Has anyone used them ??
tommo325
Post Mon Mar 05, 2012 2:28 pm
Hi guys i have been looking at some suspension kits and have come across the JOM coilover kit. I was just wondering if anyone had tried these and what they are like. Although they are cheap the reviews i have read online are good but none was e30 specific and think zoner reviews are the best to go by.
Rtaylor2208
Post Mon Mar 05, 2012 2:52 pm
There are quite a lot of threads covering this, go to the search and type in "JOM AND Coilovers" as the search criteria and you'll get lots of info.
In general though any coilovers that comes in under the the £600 mark most opinions have been its shite. And you are better to go with a Blisten B4\B6\B8 dampers and Eibach Pro Lowering Spring Kit. That will come in around the £400 mark and will ride much better.
Post Mon Mar 05, 2012 6:37 pm
8O
kitch
Post Mon Mar 05, 2012 7:42 pm
It depends what you want out of your suspension. If you're after purely lowering your car to the ground then they're fine, if you're wanting to improve the handleing of your car then as mentioned bilsteins would be alot better.
