Brake line: M.O.T question.
Ranchero
Post Sat Feb 25, 2012 3:49 pm
One of my M.O.T fails was ¨Nearside Front Brake hose excessively damaged¨
Does this just refer to the section that connects to the caliper? If so how involved is it to replace?
Jos
Post Sat Feb 25, 2012 4:32 pm
Yes, removal is a case of unscrewing it from the caliper and from the fixed line on the car and replacing it with a new one, you'll have to take the caliper off to screw the new one in (you can cut the old one out)
'94 e36 tree climber
Post Sat Feb 25, 2012 7:19 pm
Just hope its not seized to the hard brake line or you'll be replacing that too - soak it in penetrating fluid overnight before attempting to undo it.
Ranchero
Post Sat Feb 25, 2012 7:21 pm
Cheers, both of you. Any tips on stopping the brake fluid draining away or do you just bleed it and refill the reservoir?
Post Sat Feb 25, 2012 7:26 pm
Correct you just need to bleed it through after fitting the new hose.
Soak the bleed nipple in penetrating fluid too or you'll be replacing the caliper if it shears off :evil: Been there done that :mad:
Jos
Post Sun Feb 26, 2012 3:12 pm
You don't need to remove the caliper, dunno why I said that. What I probably meant was you will end up removing the caliper as the sucker will be seized on!
